Just switched to 2015 recently and I noticed move face disappered. But I quickly found direct edit and how to move faces with it. But then I noticed you can rotate solids using direct edit which apparently lets you do exactly the same thing as move body with rotate selected. So apparently the direct edit command can do everything the move bodies tool thinking about it more. I wonder if move bodies will be removed some time in the future.
I'm not looking for help, I just figured I'd comment about this and see if anyone else noticed this or other different tools that can accomplish the same task.
Hi Pball,
you can find some comment about it here:
Admaiora
