How do you display dual dimensions on a drawing? I see settings for inch and settings for metric, however I need to display them both in the traditional inch on top and metric on the bottom. I can't figure out how to do this. Any help is greatly appreciated as usual.
Randall
Solved by BMiller63. Go to Solution.
edit the dim style, (optionally save it as a new style) , click the Aleternate Units tab, and use the dropbox to set the format style:
