Are you using a Directed Angular Constraint or an Undirected Angular Constraint,
see attached ?
Directed takes into account the direction the angle in measured.
HTH
Duncan
"Derek Burns" wrote in message
news:18698676.1081944074297.JavaMail.javamailuser@localhost...
> I think I am missing a trick here somewhere.
> Does anyone know a reliable way to drive an angular constraint through and
beyond the zero degree point?
> i.e. collar on a shaft at 30deg, i want to drive it 40deg CW.
> using a start point of 30deg and an end point of -10deg causes it to bounce
off zero and return to 10deg.
> Inv8 SP1
