Inventor General Discussion
Active Member
honng
Message 1 of 5 (353 Views)
Driven length??
353 Views, 4 Replies
11-20-2012 03:58 PM
Anyone know what the Driven Length on the left list mean? How could that be created? I can change that directly. The Sketch4 below is not editable either.
Thanks for any comments.
Valued Contributor
streharg
Message 2 of 5 (332 Views)
Re: Driven length??
11-21-2012 12:58 AM in reply to: honng
Hello!
Driven lenght means that your part is driven by parameters. In your case it looks like you have content center part, which is driven by parameters used in that cc library (actually all cc profile parts are like that).
You can right click on it and use change size or replace from assembly (works only in assembly..), or just use parameters function, and edit parameters.
Factory design suite 2013 premium
Some old workstation ...
Fancy HP LCD
:smileyhappy:
New Member
HuibertvdV
Message 3 of 5 (261 Views)
Re: Driven length??
12-13-2012 04:04 AM in reply to: honng
I have a problem with displaying this driven length in my parts list. When, in an assembly, the length of a structural shape from content center is changed, in the parts list the once given length is displayed, and not the later modified dimension (driven length) how can i display the driven length in my parts list instead of the once given length.
Thanks for any comments!
Valued Contributor
streharg
Message 4 of 5 (251 Views)
Re: Driven length??
12-13-2012 04:47 AM in reply to: HuibertvdV
You have to be careful which properties you use. If you use filenames, then no, you cannot update it, it stays the way you define it when part is first saved. That's why you should use other property that actually updates (chech out frame generator and it's updating partlist).
Greg
Fancy HP LCD
:smileyhappy:
New Member
HuibertvdV
Message 5 of 5 (237 Views)
Re: Driven length??
12-13-2012 06:01 AM in reply to: streharg
Ok nice thanks my dimensions didn't match because of using the file name. I added the right colum now; thanks for the answer!
Post to the Community
New Post
Need installation help?
