If you use parameters you should be able to do this. I.e. drive the first
cylinder extension with "a". Then set the extension of the second cylinder
to (1000-"a") or whatever the final extension should be. When you then
drive "a" the second cylinder should then follow in exactly the opposite
direction.
Cheers,
--Rob Singlehurst
"Chris" wrote in message
news:46E8A1CD846E560FDFAAA96828923834@in.WebX.maYIadrTaRb...
> I have two cylinders in my main assembly, they both work just fine, the
> problem is, when one is extended, the other should be retracted, is there
> any way to do this besides driving one, and then driving the other?
