With Animator running in the left pane you should see all of your
constraints. One of them (you'll have to determine which) will control
cyl#1 position and another will control #2. Pull these into the right hand
pane and then set the start and end positions. Group them together (with
the group function). One will go from 1 to 10 while the other is going from
10 to 1.
Then run it.
Let me know if you have any other problems.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Chris" wrote in message
news:CCE11EF42042886CE2D283A5CF14864B@in.WebX.maYIadrTaRb...
> OK DAVE, Maybe i'm doing something wrong. I downloaded animator, i got it
> installed, and it opens up and everything, but i just don't understand how
> to get the parameters from my cylinder assembly into animator from my main
> assembly???? I'm pulling my hair out here.
