Hi
When i give drive & start to play , there is error come like this what i pasted a photo
so to over come this what should i do
Plz give suggestion
Make sure to expand the drive dialog and check the box highlighted in the image below:
Hope this helps.
Hi! The error usually means Inventor encouter constraint solving error at a given drive constraint value. Usually, you should be able to replicate the behavior without using Drive constraint by supplying the same constraint value at the point of failure. It is hard to tell where the problem exactly is just by looking at the picture. If you could upload the files here or send them to me (johnson.shiue@autodesk.com), I would be able to tell where the problem is.
Thanks!
