Inventor Forum
Drive limitation in Asy-Bug? IV 2013 & 2014
1 REPLY 1
gcross
215 Views, 1 Reply
The Play button is grayed out when values less than 1.000 are entered in "End" box of the the Drive Contraint dialog (see screen shots in attachments).
I can't see any reason for this. Same behavior in 2013.
I just want to drive the movement less than an inch at a slow rate which you can do with the play button.
Is this a bug?
Gary
IV2014 SP1
Tags (2)
1 REPLY 1
in reply to: gcross
It's to do with the 'Increment' setting...
With your current settings it will be outside the driven range on it's first step.
"Travel 0.218 inches with a step increment of 1.00 inches"
try changing the increment setting to be "Number of steps" and increase that value until you get the fidelity? that you require
