Inventor Forum
Drive constraints
4 REPLIES 4
KevinPinks7697
633 Views, 4 Replies
Drive constraints
How do I get two or more drive constraints to work at the same time in Inventor?
4 REPLIES 4
gsmith9810
in reply to: KevinPinks7697
One way that is possible is if all of the constraints can be related (by formula) to another.
For example: The vertical travel of a cylinder is X and the horizontal travel of two other cylinders is X * .5.
Gary Smith
Inventor Product Design Suite 2013sp2
Windows 7sp1 64-bit
nVidia Quadro 2000
mercerc
gsmith9810 comment are pretty much on the mark. Using a parameter or equation that is shared has been the only way I've found to drive two constraints at the same time. You may want to look at using Inventor Studio which will allow you to use constraints to drive and you can do more then one at the same time without have them use a equation or shared parameter.
Charlie M
Inventor Product Support Specialist
SBix26
in reply to: gsmith9810
Check out this example of what can be done using this technique: http://222.239.79.105/?module=file&act=procFileDownload&file_srl=1083525&sid=548fdc0b01129697f7cf173...
And here's the discussion forum thread: http://forums.autodesk.com/t5/Inventor-General/Inventor-is-not-a-toy-or-is-it/td-p/619006
Sam B
Inventor 2012 Certified Professional
Inventor Professional 2014 SP1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
gsmith9810
in reply to: SBix26
Used to be a tuning machine (gearbox) for a guitar delivered with the product. Driving the knob caused the post to revolve at the correct ratio.
I built a watch that animated with a single constraint. Hour, minute, second hands all ran and the date in the window changed. All at accelerated speeds since what could be more boringthan watching an animated watch?
Gary Smith
Windows 7sp1 64-bit
nVidia Quadro 2000
