Inventor General Discussion
Distinguished Contributor
jrapert
Message 1 of 8 (1,381 Views)
Drive constraint in 2013
1381 Views, 7 Replies
07-30-2012 07:37 PM
See attached screen shot.
To activate the new position of the assembly of approx 5k instances takes about 5 minutes in IV 2013 when using Drive constraint. The larger the assembly the longer it takes
In IV2011 takes about 10 seconds.
I've never seen the "Not responding" sign in Drive constraint window in previous versions.
I'm just wondering how can avoid this "New feature" of 2013.
Is anybody experienced this ?
Julian
jrapert
Message 2 of 8 (1,375 Views)
Re: Drive constraint in 2013
07-30-2012 07:42 PM in reply to: jrapert
Forgot the specs:
IV2013 Design Suite Premium
Windows7 Ultimate
12 GB RAM
1 GB NVidia Quadro 3700M graphics card
blair
Message 3 of 8 (1,369 Views)
07-30-2012 08:07 PM in reply to: jrapert
I have seen this as well in IV2013 on my systems. I don't recall it happening in IV2012. It seems like it gets lost trying to return the model back to the starting point/position.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.75
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
Employee
Yijiang.Cai
Message 4 of 8 (1,366 Views)
07-30-2012 08:22 PM in reply to: blair
I used one sample to experinece this, and it can't be reproduced. So could you attach the dataset for more invesigation?
River Cai
Inventor Quality Assurance Team
jrapert
Message 5 of 8 (1,345 Views)
07-31-2012 02:16 AM in reply to: Yijiang.Cai
The data set is too large to attach, also contains some proprietary details I can't disclose.
As I mentioned this issue only significant with large assemblies (5-10000 parts), but similar assembly in ver. 2011 did not have this problem. Seems to me that large assembly handling in 2013 is different to previous versions, and some operations significantly slower
Employee
johnsonshiue
Message 6 of 8 (1,315 Views)
08-01-2012 09:03 AM in reply to: jrapert
Hi! Without the dataset, it is extremely hard to tell where the problem is. I can provide a secure site for you to upload the large file. Please let me know via email if you would like to share.
In the meantime, could you help me answer the following questions?
1. What are the default settings in Tools->Application Options->Assembly in R2013 on your machine?
2. Could you try opening the same assembly and do Rebuild All (Manage -> Rebuild All)? What do you see?
3. Could you change Hardware setting to Compatibility mode (Tools->Application Options->Hardware) and see if it helps speed up?
Thanks!
Senior Principal SQA Engineer, Inventor
Mechanical Design
jrapert
Message 7 of 8 (1,294 Views)
08-01-2012 06:18 PM in reply to: johnsonshiue
Hi Johnson.
Thank you for your help
1 The default setting is as per attached screenshot. I've tried with different (unchecked) setting with no difference.
2 I've done  Rebuild all with no apparent problem in approx 5 minutes.
3  I'm running in Performance mode, tried Compatibility with no difference.
I'm sending you an email regarding the data set
Julian
Product Support
VinodBalasubramanian
Message 8 of 8 (1,261 Views)
08-09-2012 06:03 PM in reply to: jrapert
Can you try to uncheck the "Enable related constraint failure analysis" option and see whether it helps.
You could also try to increase the Page file size in Windows and Undo size in Inventor under Application options.
Hope it helps.
Vinod Balasubramanian
