There are no images...
Is this in a drawing. We've seen this before on this forum, where the drawing is generated by the closest model from the screen.
Are you having a similar problem as this:
Sorry about no pic. I'm working in an old version of IE and things keep getting screwy.
Hopefully this time it'll go through.
I don't need this for the .idw arena (although if that's the only way I'll live with it). I'm trying to overlap parts that represent interferences ontop of the original model. Think a robot arm on a moving assembly line. I'm trying to illustrate all the areas that are in conflict w/ it's path. In MDT I could make a part from the interference and overlay that onto the original model. Then I'd use draworder to show the red interference area over the model. In IV when I try to do this the program takes the two areas and gets them confused, then winds up showing both. In order for me to fix this I need to almost entirely recreate the the model part by part and lose the rendering. My model is around 30K parts so I really don't want to do this.
Unfortunate. So you're stuck in an old version of IE? Brutal.
