Hi!
Could anyone help me how to edit the part in drawings?
I want to add description in free space and change date.
Thank you
Solved by CCarreiras. Go to Solution.
Expand the Drawing Resources in upper left corner of browser and experiment with the items. (right click Edit)
Hi!
You can access to the file's iProperties and edit the content like the date, checked by etc etc.
You can also add other info in the Title block, deppending what you need, but in this case you have also to edit the Title block and insert ther new variables.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
