Inventor Forum
Drawing won't update
11 REPLIES 11
Message 1 of 12
cdyck
3693 Views, 11 Replies
I am using Inventor Pro 2010.
I have a model and I am driving the dimensions from EXCEL. The model updates nicely when I change dimensions but the drawing (idw) does nothing. In the browser instead of the usual tree in the view there is this red lightning bolt and under them is a big plus (+) sign and the words Solid.... after it.
I was assuming that the lightning bolt meant something needed updating, but I can't find how this is done.
Chuck
11 REPLIES 11
Message 2 of 12
in reply to: cdyck
Can you select the red lighting bolt, then RMB (right mouse button) and see
what dialoge box pops up
IV2010-Pro-sp1
Vista Business 64bit Sp2
Core i7 @ 3.07Ghz
12Gb DDR3-1600, 4 x 60 Gb SSD - RAID0
Quadro FX3800 - 191.00
SpacePilot 3.7.18 / 6.7.13
AVG8.5
wrote in message news:6278695@discussion.autodesk.com...
Chuck
Message 3 of 12
in reply to: cdyck
try a rebuild
Message 4 of 12
cdyck
in reply to: cdyck
I can't select the red lighting bolt, when I move my pointer over the bolt it says it needs updating, but the update icon is grayed out.
I allso check the delay update setting to ensure that it had not been checked.
Chuck
Message 5 of 12
in reply to: cdyck
Chuck,
Create a new empty sheet in the drawing (which you can delete later). While
that sheet is active, you can update the inactive sheets. Give it a try...
Diane Hawes
Autodesk, Inc.
Message 6 of 12
ZADKINS
in reply to: cdyck
i am using 2013 version
i had to open one sheet then got to model and save then lightning bolt disappeared
i had to do this on all sheet to get all bolts to disappear
hope this helps you
Message 7 of 12
cbenner
in reply to: ZADKINS
hope this helps you
Thanks for chiming in... but did you look at the date of the original post?
Message 8 of 12
ZADKINS
in reply to: cbenner
YES I SEEN THE DATE
BUT I WAS LOOKING FOR AN ANSWER AND THEN FIGURED IT OUT MY SELF SO I FIGURED I'D POST FOR OTHERS IN FUTURE
ALSO I DIDNT READ ALL POST SOMEONE I SEE POSTED SAME THING AS I LOL
Message 9 of 12
cbenner
Message 10 of 12
ZADKINS
thanks i shall be looking on here a lot i got a job using inventor and i have limited experience using the program.
Message 11 of 12
mrattray
There's a wealth of information here, on YouTube, in the help file, and elsewhere on the web. What program are you transitioning from? There may be a transitioning guide around (I know there's one for Solid Works as I once had cause to read it) meant to help you shift into the Inventor mind set. What industry are you in? How much experience do you have in other CAD packages?
Mike (not Matt) Rattray
Message 12 of 12
cbenner
Some tips that may make your experience here easier...
Whenever possible include files or screen shots with your questions, so we can see what's happening.  Always post what version of the software you use... a lot of people put it right in thier signatures.  If you have a performance issue question, post your system specs in as much detail as possible, it helps the techie gurus in here determine if it may be a hardware issue.  There's a lot of people in here with very different backgrounds, so more info is always better.  And good luck!   🙂
