i am using 2013 version
i had to open one sheet then got to model and save then lightning bolt disappeared
i had to do this on all sheet to get all bolts to disappear
hope this helps you
@ZADKINS wrote:i am using 2013 version
hope this helps you
Thanks for chiming in... but did you look at the date of the original post?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
'sall good. You'd be suprised how many times someone answers a 6 year old question, thinking it's from yesterday.
Welcome to the group!
Chris Benner
Some tips that may make your experience here easier...
Whenever possible include files or screen shots with your questions, so we can see what's happening. Always post what version of the software you use... a lot of people put it right in thier signatures. If you have a performance issue question, post your system specs in as much detail as possible, it helps the techie gurus in here determine if it may be a hardware issue. There's a lot of people in here with very different backgrounds, so more info is always better. And good luck! 🙂
Chris Benner
