Inventor Forum
Drawing with wires
4 REPLIES 4
mecheverry
564 Views, 4 Replies
Drawing with wires
Is it possible to generate a drawing (idw or dwg) that shows wires created in IV?
Is the wire and harness a tool only for the purposes of visual representation and pegboard creation?
Can it be expected that sometime along the next releases, electrical components could be inserted, and schematics be automatically generated?
Mauricio
4 REPLIES 4
mecheverry
in reply to: mecheverry
Never mind... Just found the procedure (go to the drawing, look for the harness in the browser, right-click and select Include Centerlines)
**The question about future possibility of automatically generating schematics stands, though**
Mauricio
I can see the name now,
"AutoCAD Inventor Electrical XXXX"
LOL
mflayler2
If you have AutoCAD Electrical you can do this now with the Import and Export from Cable and Harness. Works quite well actually.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13653850&linkID=9242016
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
mflayler2
Did you find the Nailboard option in there as well. You can lay out the harness and do Fan In and Fan Out on the contacts.
