How do I stop views from being updated with drawings (sheets)? I have a drawing of window with sash. In order to show all the parts on the sheets I need to have the window open and closed in various views and in some instances show the window with the sash removed. As soon as have what I want on one sheet it changes the others. I seem to remember something in the 'display options' tab in the edit view dialog box in previous versions but if I did I can't find it.
On another topic, how do I change the arrow size on a detail view. I can find the line weight within layers but not the arrows.
Solved by rdyson. Go to Solution.
I'm guessing that you have created position rep's in your IAM
Use them to create the views in your idw / dwg
