Inventor Forum
Drawing Views Naming
1 REPLY 1
600 Views, 1 Reply
Hi All,
I was wondering if it was possible to make my drawing views more streamlined.
Currently, when I add a drawing view, the part number and scale is pulled from the part and scale chosen. So this is good; but I would like to get the styles editor to add the actual view of the part into its name.
For example, if I choose the top view, the naming should look like the following:
TOP VIEW
XXXX-XX
SCALE: X/X
So basically I'd like to know if its possible to pull that information and display it in the naming text box. I would assume this is possible as all the other parts are possible, I dont see why this isnt an automatic default.
Any help would be greatly appreciated.
Cheers,
VCS
1 REPLY 1
Looking through Inventor I couldn't figure out how to do this.  So I did a search and found the following thread.
http://forums.autodesk.com/t5/Autodesk-Inventor/Base-and-Projected-View-Label-Name-to-match-Orientat...
They are using either VBA Macro or iLogic to change the view names.  I haven't messed around with this so I don't know how well it works.  Hope this helps.
