Inventor General Discussion
rgraham817
Message 1 of 5 (1,924 Views)
Drawing view rotation
1924 Views, 4 Replies
12-12-2012 08:04 AM
Hi Everyone
Is it possible to rotate a view?  I have a rectangular part that has the ends cut at an angle.  The part was created on an angle, not squared with the planes as you would do for a create in place. I want to lay it flat to dimension it. I need to rotate the view so my part is horizontal on my drawing. Is there a way to do that?
Randy
Inventor 2013
Windows 7
When placing your view (base view) select the box in the pic below.  Change View Orientation.  It will take you to the model and allow you to orient it in any way you want to view it in your drawing.  There are a number of tools you can use.  if you are talking about a flat surface you want square to the world in your drawing, I would use the "Look At" tool, then select a flat surface.  Playa round with it until you get the view you want then hit the check mark "Finish Custom View", to return to the drawing.
Hi rgraham817,
It occurred to me after I posted that the custom view might be a better solution, but it looks like cbenner beat me to it. :smileyhappy:
See this link for the Show Me Video that follows cbenner's suggestion:
http://wikihelp.autodesk.com/index.php?title=Inventor/enu/2012/Help/0000-What%27s_N0/0001-User_Int1/0012-Change_V12
I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 5 (1,919 Views)
Re: Drawing view rotation
12-12-2012 08:11 AM in reply to: rgraham817
Hi rgraham817,
See this link:
http://wikihelp.autodesk.com/Inventor/enu/2013/Videos/Rotate_Drawing_View
And more reading here:
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0611-Drawings611/0619-Create_d61...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
cbenner
Message 3 of 5 (1,915 Views)
12-12-2012 08:15 AM in reply to: rgraham817
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
rgraham817
Message 4 of 5 (1,910 Views)
12-12-2012 08:19 AM in reply to: Curtis_Waguespack
Thanks Curtis
Once again you have thrown me the life jacket. Much appreciated, thanks again.
Randy
Curtis_Waguespack
Message 5 of 5 (1,909 Views)
Hi rgraham817,
http://wikihelp.autodesk.com/index.php?title=Inventor/enu/2012/Help/0000-What%27s_N0/0001-User_Int1/...
I hope this helps.
Curtis
