Inventor Forum
Drawing view rotation
5 REPLIES 5
9123 Views, 5 Replies
Hi Everyone
Is it possible to rotate a view?  I have a rectangular part that has the ends cut at an angle.  The part was created on an angle, not squared with the planes as you would do for a create in place. I want to lay it flat to dimension it. I need to rotate the view so my part is horizontal on my drawing. Is there a way to do that?
Randy
Inventor 2013
Windows 7
5 REPLIES 5
Curtis_Waguespack
cbenner
When placing your view (base view) select the box in the pic below.  Change View Orientation.  It will take you to the model and allow you to orient it in any way you want to view it in your drawing.  There are a number of tools you can use.  if you are talking about a flat surface you want square to the world in your drawing, I would use the "Look At" tool, then select a flat surface.  Playa round with it until you get the view you want then hit the check mark "Finish Custom View", to return to the drawing.
in reply to: Curtis_Waguespack
Thanks Curtis
Once again you have thrown me the life jacket. Much appreciated, thanks again.
Randy
Hi rgraham817,
It occurred to me after I posted that the custom view might be a better solution, but it looks like cbenner beat me to it. Smiley Happy
See this link for the Show Me Video that follows cbenner's suggestion:
http://wikihelp.autodesk.com/index.php?title=Inventor/enu/2012/Help/0000-What%27s_N0/0001-User_Int1/...
I hope this helps.
Curtis
ronwC2GC6
This is in Inventor 2020. When you're placing a view there is this drop menu
from the View cube that allows you to select a custom view for same as you navigate in the model space.
