Is there any way to have Tangent Edges to show within all view's created on my idw automatically within the my template file or do I have to remember to double click on each of my created views per page, select display options and make sure Tangent Edges are checked on.
*See Computer Mouse is Attached Photo
unfortunately, this is not currently possible. It is being considered, according to this
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7201649&linkID=9242018
Why couldn't you have predefined views setup in a template file and have the tangency turned on there.
Then when you use this template for your drawings it would always be turned on.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Unless that's been changed in the last few releases, it doesn't work. The setting doesn't get carried over from the template.
Tried it myself on a template drawing that was mostly used for castings, at a previous employer using v2009. It's not a big problem for me now, but when I was mostly drawing cast & machined parts it was very annoying.
I'm using 2012 and while I have never used predefined views I have known those that did. It just made sense to me that having the tangency turned on in a predefined view within a template would work. In theory I don't see why it wouldn't. But, obviously it doesn't based on what you are saying. Kind of shoots the purpose of predefined views to some degree.
@Calavetta123 wrote:
... remember to double click on each of my created views per page, select display options ...
Place the Base view.
Turn on Tangent Edges
THEN
place projected views (they will pick up the same properties as the Base view).
or
place your base view and then the projected views.
Edit the base view and the projected view should pick up the same properties.
There's an ideastation topis here for you to vote on if you are still active on the forums http://forums.autodesk.com/t5/Inventor-IdeaStation/Add-the-option-of-Tangent-edges-as-default-to-app...
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
