Of course I did. But that what I say, when I re-export it in .dwg all
attribute are gone, my dimension are explode or autocad block.
Daniel Fortin ford55@globetrotter.net www.cegertec.qc.ca Tech. Mécanique
Industrielle Cegertec inc. 200, avenue du Pont Sud, Bureau 7 Alma (Quebec)
G8B 2T6 Téléphone : (418) 668-5237 (#248) Télécopieur (418) 668-0931
"Bob Van der Donck (Autodesk)" a écrit dans le
message de news: 0FC892E9EF9E71A6824391D7C6DA119B@in.WebX.maYIadrTaRb...
> While importing the dwg in Inventor, have you tried using the Options
> button?
> Deep down in the Options (the last page titled "Import destination
> options"), there is radio button that says "Titleblock". Make sure you
> select this.
> We added this option for the very same operation you want to achieve:
> convert an AutoCAD block with attributes into an Inventor title block with
> prompted values.
> Bob
> Inventor Workflow QA
