Inventor Forum
Drawing View in Raster State
27 REPLIES 27
Message 1 of 28
58962 Views, 27 Replies
Hello there,
Having this dialogue box pop up every time i print
not sure what a raster view is and how I should be turning it on /off.
any help appreciated.
Joe Banger
27 REPLIES 27
Message 21 of 28
mmistry
in reply to: nate0225
Thanks I will try it when I get raster state next
Best regards,
Manny Mistry / Project Engineer / Tyco Fire Protection Products
Tel: +44 (0) 161 477 1886 / Fax: +44 (0) 161 474 0928
Unit A3-A5, Stockport Trading Estate, Yew Street / Stockport / Cheshire / SK4 2JW / United Kingdom
mmistry@tyco-bspd.com / www.tfppemea.com
Tyco Fire Products Manufacturing Ltd. Registered in England No. 1841522. Registered Office Security House, The Summit, Hanworth Road, Sunbury-on-Thames, middlesex, TW16 5DB
[cid:image001.png@01CFB08A.4CBEC5A0]
This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential and privileged information or otherwise protected by law. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message. Any applicable rights to privilege have not been waived.
Tyco's vision is Zero Harm to people and the environment. Please consider the environment before printing this message.
________________________________
This e-mail contains privileged and confidential information intended for the use of the addressees named above. If you are not the intended recipient of this e-mail, you are hereby notified that you must not disseminate, copy or take any action in respect of any information contained in it. If you have received this e-mail in error, please notify the sender immediately by e-mail and immediately destroy this e-mail and its attachments.
Message 22 of 28
in reply to: cwhetten
Do not click the view - but click on the drawing/paper! 😉
Message 23 of 28
TRM_Plan
There is a problem abut Raster View. Around the view is a green square, and i can't switch off the Raster View option. Why?
I don't understand what this option for.
Thank
Message 24 of 28
I ran into this behavior and your post solved the issue.  Thanks, Matt
Message 25 of 28
lsbcad
in reply to: pcrawley
Thanks, very helpful your tip.
I was in face with the same issue, but now it is ok.
Leonardo
Message 26 of 28
rkahl
im having the same issue in inventor pro 2018
there is no check back for raster view only when I bring up drawing view
is there an updated method for 2018?
Message 27 of 28
fperez2XSG8E
in reply to: rms390
Double click on the view that is in raster state (green brackets will be surrounding the view) un check the raster view box.
Message 28 of 28
SER4
I had to do the classic close Inventor and restart...poof fixed😣
I should note I did get some error about a dimension to unnattached geometry, but it also went away after restarting Inventor.
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2023.4.1 (28.4.20.0); Inventor Pro 2023.4.1 (418).
