Hello there,
Having this dialogue box pop up every time i print
not sure what a raster view is and how I should be turning it on /off.
any help appreciated.
Joe Banger
Solved by cwhetten. Go to Solution.
There is a problem abut Raster View. Around the view is a green square, and i can't switch off the Raster View option. Why?
I don't understand what this option for.
Thank
im having the same issue in inventor pro 2018
there is no check back for raster view only when I bring up drawing view
is there an updated method for 2018?
Double click on the view that is in raster state (green brackets will be surrounding the view) un check the raster view box.
I had to do the classic close Inventor and restart...poof fixed😣
I should note I did get some error about a dimension to unnattached geometry, but it also went away after restarting Inventor.
