Hello there,
Having this dialogue box pop up every time i print
not sure what a raster view is and how I should be turning it on /off.
any help appreciated.
Joe Banger
Solved by cwhetten. Go to Solution.
Inventor 2013 / 2014 ?
You should be able to see which views are "raster" in the browser (they have a line through the icon) - or in the view (they have green brackets round the views).. Have a look in help for a full description, but it's a faster mechanism for getting views of complex models on a drawing sheet quickly.
You can either wait for the views to become precise before printing (green brackets disappear) - or you can turn off "Background Updates" in Tools > Application Options > Drawing. (I think it's in the same place in 2013!)
Inventor 2014 here, the Drawing views stay in raster state indefinitely on my computer. I literally let the computer sit over night to process a simple two view, one part drawing.
I think it's as simple as right-clicking the view and choosing "Make Precise". Check out the following thread:
Cameron Whetten
Inventor 2014
Cameron Whetten
Inventor 2014
Well "simple" is what it used to be.. Now its slightly less simple 😉
Having the same issue of the view being locked at 12% raster state. Removing the check from raster in the drawing view does not work. Righ clicking to make all views precise does not work. Let the file run over night does not work. Opening and placing new view on highest end workstation does not work. Assembly file size 4,187 KB
Raster view locked at 12%. Will not update over night or other workstaions placing a new view. Assembly file size 4,187 KB
Hi SysDesign,
It looks like you've posted this two places. I responded to your other post before seeing this one, so please update that post with more details as requested.
Link to your other post:
http://forums.autodesk.com/t5/Inventor-General/Drawing-view-crossed-out/m-p/4841741#M498835
I hope this helps.
Curtis
I am coming from using inventor 12 now 14 and when you turn off the raster state the view looses the features. see attached drawing top view from base does not show outside features, please help
The drawing file by itself doesn't help us. We need all the parts / assemblies included in the drawing as well. Upload those as well, and we'll take a look at it for you.
Rusty
Hi mmistry,
You might make sure all of the files involved are migrated (saved as 2014 files). This seems to have solved some Raster View related problems for other users.
I hope this helps.
Curtis
Curtis & Rusty
thank you fro suggestion but there is no iproperty on the original model. I have sent the .ipt file by mail to Rusty.
sorry is replied to you community mail - Community Mailer <mailer@lithium.com>. please see attached.
In 2014 and now in 2015, even after I set the drawings to not do background it was still stuck in raster state. I was finally able to solve this by supressing the view and then unsupressing it. This brought it out of the raster state.
