Inventor General Discussion
*Expert Elite*
cbenner
Message 1 of 4 (464 Views)
Accepted Solution
Drawing Symbols - User Defined
464 Views, 3 Replies
10-05-2012 08:45 AM
Is there a quick easy way to delete a user defined drawing symbol from all sheets of an IDW at one time?  Without having to open each page?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Hi cbenner,
Here's a real quick iLogic snippet to do this.
sName = InputBox("Enter the name of the sketched symbol to delete", "iLogic", "")
Dim myIDW As DrawingDocument
myIDW = ThisApplication.ActiveDocument
Dim oSheets As Sheets
oSheets = myIDW.sheets
Dim oSheet As Sheet
Dim oSymbol As SketchedSymbol
For Each oSheet In oSheets
    oSheet.activate
    For Each oSymbol In myIDW.ActiveSheet.SketchedSymbols
    If oSymbol.Definition.Name = sName Then
    oSymbol.Delete
    Next
Next
Creating a Basic iLogic Rule
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
*Expert Elite*
Curtis_Waguespack
Message 2 of 4 (457 Views)
Re: Drawing Symbols - User Defined
10-05-2012 09:04 AM in reply to: cbenner
Hi cbenner,
Dim oSheet As Sheet
    oSheet.activate
    oSymbol.Delete
    Next
Next
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
cbenner
Message 3 of 4 (440 Views)
10-05-2012 10:30 AM in reply to: Curtis_Waguespack
Hey thanks!  I never got into ilogic much.... never thought I'd need it.  Look how wrong you can be!  :smileyvery-happy:
ChrisB
*Expert Elite*
cbenner
Message 4 of 4 (389 Views)
10-08-2012 04:47 AM in reply to: Curtis_Waguespack
Hey Curtis,
Tried this rule this morning and it worked great, except for the "End if" statement... there was no preceding "if".  I took that line out and the code worked fine... pretty sweet actually!  Thanks for sharing!
Chris
ChrisB
Announcements
Need installation help?
