Is there a quick easy way to delete a user defined drawing symbol from all sheets of an IDW at one time? Without having to open each page?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by Curtis_Waguespack. Go to Solution.
Hi cbenner,
Here's a real quick iLogic snippet to do this.
sName = InputBox("Enter the name of the sketched symbol to delete", "iLogic", "")
Dim myIDW As DrawingDocument
myIDW = ThisApplication.ActiveDocument
Dim oSheets As Sheets
oSheets = myIDW.sheets
Dim oSheet As Sheet
Dim oSymbol As SketchedSymbol
For Each oSheet In oSheets
oSheet.activate
For Each oSymbol In myIDW.ActiveSheet.SketchedSymbols
If oSymbol.Definition.Name = sName Then
oSymbol.Delete
End If
Next
Next
Creating a Basic iLogic Rule
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
Hey thanks! I never got into ilogic much.... never thought I'd need it. Look how wrong you can be!
Chris Benner
Hey Curtis,
Tried this rule this morning and it worked great, except for the "End if" statement... there was no preceding "if". I took that line out and the code worked fine... pretty sweet actually! Thanks for sharing!
Chris
Chris Benner
