Inventor Forum
Drawing Symbols - User Defined
3 REPLIES 3
cbenner
765 Views, 3 Replies
3 REPLIES 3
Curtis_Waguespack
in reply to: cbenner
Hi cbenner,
Here's a real quick iLogic snippet to do this.
sName = InputBox("Enter the name of the sketched symbol to delete", "iLogic", "")
Dim myIDW As DrawingDocument
myIDW = ThisApplication.ActiveDocument
Dim oSheets As Sheets
oSheets = myIDW.sheets
Dim oSheet As Sheet
Dim oSymbol As SketchedSymbol
For Each oSheet In oSheets
    oSheet.activate
    For Each oSymbol In myIDW.ActiveSheet.SketchedSymbols
    If oSymbol.Definition.Name = sName Then
    oSymbol.Delete
    End If
    Next
Next
Creating a Basic iLogic Rule
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
cbenner
in reply to: Curtis_Waguespack
cbenner
Hey Curtis,
Tried this rule this morning and it worked great, except for the "End if" statement... there was no preceding "if".  I took that line out and the code worked fine... pretty sweet actually!  Thanks for sharing!
Chris
