There are a couple of things I simply can't figure out how to customise in the style manager & it's driving me up the wall. It doesn't help that I don't have much CAD experience and don't know the lingo. Here goes:
#1 - When dimensioning holes I get 2 arrows going across the diameter of the hole. I would rather have a single arrow from the text label to a point on the circumference. It seems to work this way if I have a radius, but not for a hole.
#2 I would like all dimension lines and text to be a different colour (blue) than the drawings (black). I've managed this, but at the expense of turning all the text (including in the "Field Text" (i.e. the box in the bottom right with Designer name, date, title etc...) Can I leave the field text black?
I found a way to accomplist #1 using Layers... still no luck with #2 though...
You will need to create a different text style that is blue, then use that for your dimension styles.
