Hello all ,
Thank you for the help that you gave me on my last question
What I would like to know now is - How do I set up a drawing sheet template , complete with line weights , styles dimension styles , just like I have in Autocad .
Many thanks again for your help .
Regards
Ivan
Hello ivan56,
You can make all the styles way for your drawing in MANAGA>STYLES EDITOR:
When you finish all your customizations, go to SAVE AS and click on SAVE AS TEMPLATE.
Save this template on the default folder.
Please click "Accept as Solution" if this response answers your question.
Ivan,
See if these links help you.
http://www.youtube.com/watch?v=yUKfI1hPNsE
http://www.youtube.com/watch?v=_Lov4NhKtgY
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
