Scott,
Small world :oD
A few things..
I can open the idw's both the title block template and the main assembly
idw. I am running r10 SP3. However....
1) I open the idw disconnected( skipping the option to resolve the
references) and it opens. If I can have the iam and ipt's I may be able to
look into the problem in more depth
2) I open the title SMB-robo template in r10 with no problem.
3) I use the DRTW using the SMB-robo and applied it to a simple idw I have.
This worked fine with no errors.
So with those results, we need to try to get closer to you actual scenario
I will need the following
1) The iam and ipts as stated above
2) The idw that you are mapping the template idw too using the DRTW
3) I have AOL, what version of AOL. I can uninstall mine and see if I can
reproduce your problem..
4) Do you have any SP's installed for r10
I think that's it for now, once I get all these answers 😉 I can
investigate a little more
Thanks Scott
Lisa
wrote in message news:5178194@discussion.autodesk.com...
Lisa:
I've got more problems than described in my earlier post:
My main assembly idw was just about completed, and I decided to uninstall
AOL instant messenger (AIM) from my computer. As with any install/uninstall,
I shut down all progs before starting. Uninstalll re-started my
machine...... (well, you know, the normal "need to restart" message.
I started working again, and on a purchased part idw (a cam follower) I have
a symbol for describing purchased parts. It's a box with prompted inputs for
part #, manufacturer, supplier, and description of the item. I oticed that
the text in the symbol wasn't laft-justified as I wanted, so I closed that
idw and opened my template fil, to correct the symbol's text. I've a lot of
idw's that use the same symbol, so I started the DRTM and attempted to
update all the idws in my project. During operation of the transfer manager
(and the image I attached earlier shows it was working on the main assembly
idw) I got the message.......
Now, when I attempt to open the main assy idw, Inventor quits. The window
closes without any message. The IV window just closes. I can open any other
part or assy idw..... just not the General Assembly file.
I'm using IV10, and the idw contains 3 sheets.
Egad! - this GA took many hours to create
