Is there some way in an Inventor idw drawing to 'hide' a page. I have created an extra page with information for future changes but do not want it to printed or be counted in the total number of sheets.
Solved by cbenner. Go to Solution.
In your sheet list, highlight the sheet you want to "hide", right click and select Edit Sheet. A dialog opens and you can check, under Options, to either Exclude from Count, and/or Exclude from Printing.
I think this is the only way to do this and still have the sheet available for editing. I would assume that later, you could uncheck those and add it to the final sheet set.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
