I'm trying to make a blueprint for a builder and I want the dimensions to show up headon facing me.
What do I do... I've sat through a few youtube videos none covering this.
I'm not sure what you mean by 'head on', but if you RMB while placing the isometric dimension and select "Annotation Plane" and then 1 of the options you can get different results for the dimension. Hope this helps.
Sounds like you have zero training in and with Inventor software.
This would be a start:
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
This would be another:
Thanks for the kind reply. I'm not sure what you right-click on, I've tried right-clicking on everything and I can't get a pop up window with Annotation Plane in the menu.
