Inventor General Discussion
0 Kudos
Post 1 of 8
Drawing files, view problems.
571 Views, 7 Replies
01-02-2013 08:06 AM
I am having an issue with drawing files. I have set views on assembly files. But on the idw file it is showing wrong views... And this is making problems when i am trying to give dimensions.  I have attached jpg files.
Is the item orientated correct to the 3D triad icon in the corner of the modeling window?
The orientation of drawing views has nothing to do with the view cube, so even if you change the "Front" view on your view cube, it will have no effect on how it is displayed in a drawing.  The drawing looks to the part / assembly origin planes.
In order to get your assembly to show properly in the drawing, you need to constrain it to the origin planes.  The positive Y-axis points up, and the positive X-axis points to the right when you are looking at the Front view.
779 Kudos
Post 2 of 8
Re: Drawing files, view problems.
01-02-2013 09:05 AM in reply to: tolgacankurt
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
0 Kudos
Post 3 of 8
01-02-2013 10:39 PM in reply to: blair
no, it is different as seen on attached pic. How i can correct it?
269 Kudos
Post 4 of 8
01-03-2013 09:36 AM in reply to: tolgacankurt
0 Kudos
Post 5 of 8
01-04-2013 05:15 AM in reply to: cwhetten
Thanks for answers
Active Contributor
0 Kudos
Post 6 of 8
05-06-2013 07:12 AM in reply to: tolgacankurt
But do you reconstraint the assembly to another origin axis?
Sorry Im new to this
63 Kudos
Post 7 of 8
05-06-2013 08:20 AM in reply to: cahoe
RIGHT-CLICK ON THE DRAWING SPACE, SELECT GENERAL DIMENSION TYPE - PROJECTED (VS TRUE)
jvj
779 Kudos
Post 8 of 8
05-06-2013 08:44 AM in reply to: cahoe
If the model is slightly off to the base-views in the View Cube, then you would want to un-ground the model (should be only the first part placed in the IAM that is automatically grounded, unless you have grounded more yourself). You can then ground any part (face or axis) to what every Origin Plane you wish.
Win7-64
Delta Tau Chi ΔΤΧ
