Inventor General Discussion
New Member
denick
Message 1 of 4 (135 Views)
Drawing based .ipn shows trimming surfaces even visibility is turned off.
135 Views, 3 Replies
10-01-2012 10:51 AM
Drawing based on .ipn shows (should not show) surfaces used to trim, even their visibility are turned off.
Drawing is normal if based on .iam.
Only one part of the assembly is the problem. Other parts, also with trimming surfaces, are shown normal.
Please see images in .pdf attached.  Thank you!
That simptom only happened when the .idw was generated from a .ipn that was generated with view representation of .iam set 'master'. Othervise it was normal, so I use now a view representation other than master to create .ipn for this assembly.
So I found this solution, and give this subject as solved.
Thank you Mr. James.
*Pro
jletcher
Message 2 of 4 (129 Views)
Re: Drawing based .ipn shows trimming surfaces even visibility is turned off.
10-01-2012 11:01 AM in reply to: denick
Can you post the part that is doing this I will test on my machine see what I get.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
New Member
denick
Message 3 of 4 (103 Views)
10-02-2012 07:32 AM in reply to: jletcher
New Member
tjvz85
Message 4 of 4 (29 Views)
09-18-2014 12:52 AM in reply to: denick
This unfortunately does not ring true in all cases. I have all involved assemblies on either default view or a different LOD, but still there is ONLY ONE part's trim surface visible in my drawing based on a .IPN.
Any input will be appreciated.
Theo van Zyl
IV14
