Drawing based on .ipn shows (should not show) surfaces used to trim, even their visibility are turned off.
Drawing is normal if based on .iam.
Only one part of the assembly is the problem. Other parts, also with trimming surfaces, are shown normal.
Please see images in .pdf attached. Thank you!
Solved by denick. Go to Solution.
That simptom only happened when the .idw was generated from a .ipn that was generated with view representation of .iam set 'master'. Othervise it was normal, so I use now a view representation other than master to create .ipn for this assembly.
So I found this solution, and give this subject as solved.
Thank you Mr. James.
This unfortunately does not ring true in all cases. I have all involved assemblies on either default view or a different LOD, but still there is ONLY ONE part's trim surface visible in my drawing based on a .IPN.
Any input will be appreciated.
Theo van Zyl
IV14
