Inventor Forum
Drawing angle use quadrant by default
4 REPLIES 4
z.baczo
1332 Views, 4 Replies
Hello everyone,
Is there a way to make the "Use Quadrant" option by default when placing andular dimensions in drawings (instead of right-clicking-->Options-->Use Quadrant (see attached) every single time I place an angular dimension)?
I'm sure it's possible, I just can't find the option to do that...
Thanks in advance,
B.
Baczó.
4 REPLIES 4
Nicolas.Bourquin
in reply to: z.baczo
Hi Z.baczo,
Probably what you are looking for can be set in the dimension style as indicated in the picture here below.
Note 1: to enable this change for all the future drawings, you could make this modification directly in the dimension style of your template(s).
Note 2: it is also possible to save this change in the "style library" as indicated in the second picture here below..
I hope that can help you.
Best Regards.
Nicolas Bourquin
z.baczo
in reply to: Nicolas.Bourquin
Hello Nicolas Bourquin,
This is exactly what i was looking for. Thanks!
Baczó.
2023 Inventor - quadrant default option is not working.
Hi Tatiana,
I cannot seem to reproduce the "Use Quadrant" issue on 2023.3.1 update. If possible, please share the file that exhibits the defective behavior.
Many thanks!
Software Test Engineer
