I have downloaded inventor professional 2015 64 bit. I am keen to look at this as I want to try out HSM works for inventor.
when trying to run the install file I get the following message
"Product download consists of multiple files. At least one file os missing or has not been downloaded yet"
I had previously tried the manager install but this seems to stall at 10GB.
This is the first time that I have experienced any issues with any of the student downloads.
Please could you advise.
Thanks in advance,
Tony
You should have two installatin files:
Autodesk_Inventor_2015_English_Win_64bit_dlm_001_002.sfx.exe
Autodesk_Inventor_2015_English_Win_64bit_dlm_002_002.sfx.exe
If you just got the first one, most likely your browser had the second file blocked. Try disabling browser's ad blocke.
When I use the Browser download method (using IE) I have to go back a second time and start the download again and then pay attention to the lower right corner of screen to get the part 2 of 2 download.
hi JK,
i am stuck with the same error
i have checked i dont have the second file Autodesk_Inventor_2015_English_Win_64bit_dlm_002_002.sfx.exe
i also do not get any pop ups etc - is there another way i can get the second file.
i have tried downloading twice already - same result, only 1 file
My reference was to using IE browser download.
You can change address of that page, like that :
part 2 : http://trial2.autodesk.com/SWDLDNET4/2015/INVHSM/DLM/Autodesk_INVHSM_English_Win_64bit_dlm_002_002.sfx.exe
Try it, good luck,
