Hi,,
I'm Dedet
Please kindly help me, I have Serial Number AutoCAD Inventor 2011, i'm always upgrade,,now the sofware upgrade Product Design Suite 2015,, but i'm will downgrade to AutoCAD Inventor 2011, because i'm partner use AutoCAD Inventor 2011 Version, when I move my license to other PC not activated, autodesk not permite
this isi replay from Autodesk
AutoCAD Inventor Suite 2011 was a Previous Version request done on 4/24/2013. It is currently not under the Previous Version Eligible list permitted by Autodesk.
I am very grateful to you all,,
Thank and best regard
Dedet
Hi!
When in Active subscription, You have the possibility to work with 3 previous versions: 2015 and 2014,2013,2012... now versions 2011 are out, not supported, so you will not have codes to install again 2011 versions... not good news for you... sorry.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
