Inventor General Discussion
New Member
Preyno
Message 1 of 4 (254 Views)
Dowels in Holechart
254 Views, 3 Replies
11-28-2012 08:06 AM
Autocad user here trying to get to grips with Inventor..
My problem is when creating dowels in my models they show up the same as normal drilled holes in the hole chart.
I know I can create a symbol to drop over them (have done this for now) but its the holechart that I really need help with. We make parts with many different hole types and trying to sort dowel holes from drill holes is very time consuming and most importantly leaves room for error which can be very costly in our business (machine tool design & manufacture).
Anybody know of a solution to this problem?
Thanks in advance
Paul
RobJV
Message 2 of 4 (217 Views)
Re: Dowels in Holechart
11-29-2012 04:59 PM in reply to: Preyno
probably not the best solution but one off the top of my head - you could simply extrude the holes for dowels and use the hole command for drilled holes.
Only problem (probably a large problem) is no hole table will be created for dowels.
Rob
New Member
Preyno
Message 3 of 4 (209 Views)
11-30-2012 01:26 AM in reply to: RobJV
Thanks for your reply Rob, I dont think that will really help with our hole table description problem, oh well back to manual editing :smileysad: .
*Pro
sbixler
Message 4 of 4 (185 Views)
11-30-2012 05:44 PM in reply to: Preyno
Are your dowel holes the same size as the drilled holes?  Only if they're the same nominal size as other holes will they roll up together.  Can you post a sample drawing that illustrates the problem?  I won't suggest that there isn't a lot of room for improvement in Inventor hole charts, but your problem might still be solvable.
