Inventor Forum
Double tables
4 REPLIES 4
Leanderjk
300 Views, 4 Replies
Double tables
I was wondering if I'm able to create two tables in an iassembly, like one table for size and another for different components in the same assembly.
I have a vague memory of an old assembly having this but I can't find it or it's just a figure of my imagination.
Thanks in advance!
Regards, Leander
Work: Autodesk Inventor 2010
Home: Autodesk Inventor 2013
4 REPLIES 4
Cadmanto
in reply to: Leanderjk
Leander,
If you are talking about an actual assembly you can insert tables throu insert object.
If you are talking about an assembly drawing you can add as many general tables as you need.
If it is something different then this please clarify.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Leanderjk
in reply to: Cadmanto
I'm trying this in an .iam.
I've attached some test files to help me explaining.
I'm trying to create an iassembly which allowes me to replace Part1(to a longer or shorter one) and at the same time have a different table with which I'm able to include or exclude Part2.
So my end product should be an assembly with two tables separate left in my object browser.
Thanks in advance!
Regards, Leander
Cadmanto
For whatever reason I cannot open your zip file.
Best Regards,
Scott McFadden
Leanderjk
Little responce,
I haven't found the solution yet but I do have a work around using Level of Detail Representations in combination with a Ipart/Iassembly.
Being able to select the size with a table and excluding objects using the LOD.
Regards, Leander
Regards, Leander
