Inventor Forum
double curved stringer ??
6 REPLIES 6
ayub.shahid
453 Views, 6 Replies
Hi expertise,
Please can anyone explain how can i create this type of unfoldable stringer like in image, right side stringer has one radius but the left side of stringer has two redius.
it's just for practice and to see how Inventor handle this type of work.
i also attached dwg if in case you need that.
Thank you so much in advance.
Regards.
6 REPLIES 6
JDMather
in reply to: ayub.shahid
The dwg file you attached looks nothing like the image you attached.
I don't understand what you are trying to do?
ayub.shahid
in reply to: JDMather
i'm sorry for wrong attachment,now it's correct.
i want to model this stair with inventor and i want to understand the method of creation of stringers.
once agian thank you so much.
Run=200mm
Rise=170mm
Stringer Hight=250mm
Hi ayub.shahid,
Attached is an example file that demonstrates one quick method to create the whole flight and flatten it. There might be other ways to do this as well.
Having said that, it just occured to me that you asked for the stringers, rather than the stairs, so I've attached those files as well.
These might not be exactly what you're after but should give you some ideas.
You did not indicate which version of Inventor you have, so I've done this in the oldest version I have, which is Inventor 2010. So hopefully you will be able to open the attached file.
I hope this helps.
Curtis
what a great help SIR, thank you so much from the deep of my heart.
i always remember your help whenever i i'll do this type of work. hv a nice day thanks agian. Ayub
may i ask one more question please, how can i use for stringer any rectangular profile like (150*150*6)  rather then plate.
could you explain this. thanks.
ayub.shahid
can any one help me about attached 3D Solid DWG file. wanna modeling in Inventor its high level complex structural modeling.
i'm interesting to know just stringers Modeling.
thanks in advance.
