Hi expertise,
Please can anyone explain how can i create this type of unfoldable stringer like in image, right side stringer has one radius but the left side of stringer has two redius.
it's just for practice and to see how Inventor handle this type of work.
i also attached dwg if in case you need that.
Thank you so much in advance.
Regards.
Solved by Curtis_Waguespack. Go to Solution.
The dwg file you attached looks nothing like the image you attached.
I don't understand what you are trying to do?
i'm sorry for wrong attachment,now it's correct.
i want to model this stair with inventor and i want to understand the method of creation of stringers.
once agian thank you so much.
Run=200mm
Rise=170mm
Stringer Hight=250mm
Hi ayub.shahid,
Attached is an example file that demonstrates one quick method to create the whole flight and flatten it. There might be other ways to do this as well.
Having said that, it just occured to me that you asked for the stringers, rather than the stairs, so I've attached those files as well.
These might not be exactly what you're after but should give you some ideas.
You did not indicate which version of Inventor you have, so I've done this in the oldest version I have, which is Inventor 2010. So hopefully you will be able to open the attached file.
I hope this helps.
Curtis
may i ask one more question please, how can i use for stringer any rectangular profile like (150*150*6) rather then plate.
could you explain this. thanks.
can any one help me about attached 3D Solid DWG file. wanna modeling in Inventor its high level complex structural modeling.
i'm interesting to know just stringers Modeling.
thanks in advance.
