Solved by Cadmanto. Go to Solution.
hello and welcome. I am not sure what you are asking.
It is always preferable to attach your model to your post - and remember to roll up the EOP first to reduce file size.
Or at least some screenshots.
Generally in sheet metal it is better to model up in the bent up position first with flange and contour flange etc, rather than modeling up flat and then bending afterwards. So rather use face and flange and then flat pattern at the end.
I would only use fold in exceptional circumstances when all the other options won't work.
Welcome to the forum.
It would really be helpful if you would post some images showing what you are describing.
First guess is if you have a plane down the middle of the box, just project from there.
What version are you running?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hello, sorry for being so vague.
I am using Inventor 2013.
So in the image below, I have my sketch. This will be the back of my box. On the top of the box, I want to have a hole. Now I think I can do it two ways.
In the picture below, I use a flange and then create a new sketch on that flange, add my hole, then cut it out using the cut tool.
Or I can right click on my 3d model and add a new sketch to that, then add a construction line and fold it like that (not correct size for the top in picture, but just to show what I mean).
Do not use Fold (unless there is no other way).
From what you have shown so far - a Contoured Flange would have created those two faces with just two simple lines.
Keep your sketches simple.
Chamfers can be added as features.
Only need sketch centerpoints for hole features.
If you are not sure how to finish it all up using sheetmetal tools - use the standard modeling tools to model in finished form and someone will demonstrate how to do the same model with sheet metal tools.
After looking at your images (and thank you for providing them. Makes diagnosis much easier) I would definately go with a a flange. Then use extruded cuts to create your cutouts, but it looks like you are already well on your way.
