Inventor General Discussion
Valued Mentor
40 Kudos
Post 1 of 6
Do I need to migrate Custom Inventor Material Library from 2013 to 2014
667 Views, 5 Replies
08-28-2013 08:41 AM
I created a custom Inventor Material Library using Inventor 2013.  I want to use that library in Inventor 2014.  I renamed the "out of the box" Inventor 2014 Material Library and copied the Inventor 2013 Custom Inventor Material library to the shared network location we use for our Inventor styles library.  I am able to to see our custom Inventor material library in Inventor 2014.  DO I NEED TO MIGRATE IT FOR INVENTOR 2014.
What is the proper procedure when you upgrade Inventor and you have a custom Inventor material library?  Do you just copy the custom library to the design data folder and start to use it, or do you use the 'out of the box" Inventor Material Library and copy the custom materials to the that library every year.
Any help would really be appreciated.
Thanks!
John C Weiss Jr.
CAD Administrator
Follett Corporation
John,
There is no need to migrate an .adsklib file from 2013 to 2014. You can simply copy it in to the desired location & ensure it's referenced from your project settings. Note that once you've written new data to an adsklib file from 2014, you might experience issue if you try to use the exact same file with 2013, though, so ensure you keep your versions separate, if required.
In general, I'd suggest leaving the Inventor library in it's as-shipped form & adding your own custom materials/appearances to your own custom library, as opposed to making changes to the Inventor library.
Hope this helps,
Chris
Board Manager
123 Kudos
Post 2 of 6
Re: Do I need to migrate Custom Inventor Material Library from 2013 to 2014
08-28-2013 01:48 PM in reply to: jweiss
John,
Hope this helps,
Chris
Chris Mitchell
Inventor Customer Engagement Team
Valued Mentor
40 Kudos
Post 3 of 6
08-28-2013 01:50 PM in reply to: ChrisMitchell01
Thanks for the information Chris!
John C Weiss Jr.
CAD Administrator
Follett Corporation
Distinguished Contributor
12 Kudos
Post 4 of 6
09-22-2014 01:46 PM in reply to: ChrisMitchell01
Forgive me, but I am basically going to ask the exact same question just to verify for 2015:
I created an .adsklib file in 2014.  It contains a few custom materials.  We used it in conjunction with the "out of the box" material library that came with Inventor 2014.
We just upgraded to Inventor 2015.  We will continue to use the standard material library, but we also want to use the custom materials created in 2014.  Is there any need to migrate the custom .adsklib from 2014 to 2015?
Board Manager
123 Kudos
Post 5 of 6
09-22-2014 04:14 PM in reply to: iamerm
No need for migration to use that adsklib file with 2015. Note that once you write to it using 2015, I don't believe you'll be able to use it anymore with 2014.
Chris
Chris Mitchell
12 Kudos
Post 6 of 6
09-23-2014 05:48 AM in reply to: ChrisMitchell01
Thanks, Chris!
