When creating a drawing in Inventor 2015, the threaded holes are represented as trough holes, altough the dimensioning works. Attached an example created in inventor 2014 (correct) and in inventor 2015.
Is there any workaround or solution?
Nuno
Solved by JDMather. Go to Solution.
Double click on the view and check Display Options for threads.
Here is your answer.
Sam B
Inventor 2012 Certified Professional
Inventor Professional 2015 SP1
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
