I have section of assembly which contains reference part on drawing view. In "Drawing View " dialog box and Model State tab I choose "Part " option as Reference data of Line style. In earlier versions of Inventor (ca. <2010), this choice meant that the cut portion of the reference was dashed, like the other, normal parts. For some time and now it does not. It is only standard style of line now. The same effect I can easily get with " Referenced Parts " option in this dialog window. This is no facility. Why?
I noticed with sadness: the higher version of the program - the more inconvenience (and bugs) .
Look at drawing in attachment, View 4, Skech 1 on green lines for example. Earlier've been better...
I use this program since version 3.0.
Thank you for your attention
_______________________________________________________
Windows 10 64B + Product Design Collection 2021+ASM 2018
1. HP Z2 Tower G4: Intel Core i7-8700K CPU@3.70GHz + Quadro P2000
2. GIGABYTE EX58-UD5: Intel Core i7 920 (2.66GHz to 3.6GHz) + Quadro FX4000
