Inventor Forum
DISAPPEARING CONSTRAINT POINTS IN INVENTOR
5 REPLIES 5
351 Views, 5 Replies
The green balls that should appear when hovering over a constrianed point as stopped appearing.  Is there toggle or someother way to "turn" these back on?
5 REPLIES 5
JDMather
What version of Inventor?
Constraint Persistence?
Constraint Options?
in reply to: JDMather
I am a new user, this happened in the 2012 Tuitorial.  Wondering if maybe somehow I accidently chnaged something.
JDMather
Are you in an active sketch?
Attach the ipt file here.
You might also indicate the exact url step where you are in the tutorial.
Curtis_Waguespack
Hi
As JDMather suggested, this is likely due to the Constraint Persistence setting. See Paul Munford's article on this subject at this link:
http://cadsetterout.com/inventor-tutorials/inventor-constraint-persistence-my-best-friend-my-worst-e...
I hope this helps.
Curtis
Seems to be work ok, think I may have been doing something wrong.
Thanks for your help
Ray
