The green balls that should appear when hovering over a constrianed point as stopped appearing. Is there toggle or someother way to "turn" these back on?
What version of Inventor?
Constraint Persistence?
Constraint Options?
I am a new user, this happened in the 2012 Tuitorial. Wondering if maybe somehow I accidently chnaged something.
Are you in an active sketch?
Attach the ipt file here.
You might also indicate the exact url step where you are in the tutorial.
Hi
As JDMather suggested, this is likely due to the Constraint Persistence setting. See Paul Munford's article on this subject at this link:
I hope this helps.
Curtis
Seems to be work ok, think I may have been doing something wrong.
Thanks for your help
Ray
