Inventor Forum
Disapearing Dimension lines
8 REPLIES 8
Message 1 of 9
532 Views, 8 Replies
Hello
I have a problem with Inventor 2013. The dimension lines have disapeared and I have no idea how to bring them back. I've been through all  the  dimension styles and layers to make sure I hadn't turned one off
All other drawings are fine and if I create another even using the same model it works just fine but I'd rather find out why than re-do the whole drawing.
 Here's an example of the problem
8 REPLIES 8
Message 2 of 9
Cadmanto
I am not using 2013 yet, but if you do a print preview are they there?
Also, I know you have checked the new dim style settings, but did you look at these settings?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 9
mrattray
Did you try a reboot?
Mike (not Matt) Rattray
Message 4 of 9
in reply to: Cadmanto
Thanks for the quick response
print preview and actually printing the file shows exactly the same result as the screenshot.
I also tried both of these settings to no avail.
Message 5 of 9
in reply to: mrattray
I tried rebooting and I also tried opening the drawing on 2 other computers
Message 6 of 9
Cadmanto
You wouldn't happen to still have 2012 running somewhere to try this would you?
If so and it shows the extention lines I would say you uncovered a bug in the software.
Best Regards,
Scott McFadden
Message 7 of 9
Ray_Feiler
Someone else with the same issue.
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-missing-dimensions-in-drawing/td-p/346...
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 8 of 9
in reply to: Ray_Feiler
Thank you, I hadn't found anyone else with the same issue.
I also noticed that page 1 of my drawing is perfectly fine while page 2 is broken. I am starting over the drawing as it probably will be faster than trying to salvage the old one.
Message 9 of 9
mrattray
Maybe they'll fix it in IV 2017.
