Inventor Forum
Disable automatic ray tracing in 2012?
2 REPLIES 2
erik
2700 Views, 2 Replies
Is it possible to prevent ray tracing from automatically starting every time the realistic visual style is chosen?  I'd rather not have to click the 'Ray Tracing' button in the Appearance panel or click the 'Disable' button in the tracing dialog box.
I've searched through the application options and don't see any options for ray tracing.  Hopefully I'm missing something obvious here.
Thanks!
2 REPLIES 2
SveinE
in reply to: erik
Tools - Application Options - Display - Settings - "UnCheck" Use Raytracing .... br Svein-Erik AGS
erik
in reply to: SveinE
Thanks!  That did the trick.
One observation: you also need select the 'Use Application Settings' radio button to force  files from using saved ray trace settings.  I had a fuel rail design that must have saved previous ray tracing info.  Selecting this option stopped it from tracing even though it was disabled in the application options.
